I have a customer I recently put up an electric fence for and when it rains the trip switch in he house goes,
Any ideas what could be causing this , and how would be the way to diagnose it.
I have one gateway where I ran a plain wire under, through an alkathene pipe instead of lead out as I ran out of lead out I'm wondering if water is gathering in this pipe causing a short.
The unit is the only other problem I can think of.
And the remedy for this would be what, would running line out instead of the line wire be the solution also an additional earth stake knocked in I'm thinking.
If the trip has an RCD then the leakage current to earth will probably be the cause. Wet and more current to earth . 30 ma trip I expect?
Layman's terms please!
Residual current device. It measures current out in the positive and current back in the negative. Any difference is going to earth. More than 0.03 Amp then it trips. A tiny leakage current to earth will trip it. A person should be safe taking a 30 ma 240 v shock which is why they are fitted to socket ringmains
