Schliesing vanity
Swampster
You can get a similar finish using a Shultz paintable stone chip
Works best on sand blasted surface
You can adjust the roughness of the finish by a number of ways
The finish is a rubberised textured surface which is ideal for applying a coat of 2 pak paint on to for a high strength gloss finish
You can apply more than one layer for a thicker coating is required but it the first coat needs to set fully first 24-48 hrs
It can be sanded once set as well
NB make sure it's paintable as the non paintable comes in the same tin !!!
