  • Replies 53
Another question can you still get the name plaques for the 090
Haven't found a supply for anything other than the newest type.
Btw - what cycle do you wash them on?
Alec
Alec
Ha ha I hadn't noticed that one :thumbup::thumbup:
Is the newest type very different from the older emblems
There are different designs to the top cover.
The earliest ones have the cast Stihl logo painted white over the red or orange and transparent transfer which goes in the rebated section - saying 090 or 070, with or without AV depending on model.
The second type has two rebates, one in the top cover and the other in the air filter, lining up to take two separate rivetted in plates. The upper one says Stihl, the lower one has the model number and AV if appropriate.
The latest type has a single rebate in the air filter cover (none in the top cover) and stick-on label with both Stihl and the model, with or without AV.
It's only the later type which is still available. There are bad copies of the straight 090 label.
Alec
