Does anybody know what side angle the Kubota G23 will safely work at? Got a job to do with a bit of an embankment and before I brick myself (normally only have jobs on flat ground) wondered if anybody else takes their machine to its limit.
Hi Ragnar,
As a rule of thumb I would use 20 degrees as a safe side angle to run an oil sump engine for extended periods though I have no knowledge of the Kubota engine in particular.
I would top the oil up just a bit over the full mark to be on the safe side, it won't hurt it.
Hope this helps.
Think they say 10 degrees side angle and 15 degrees up and down. I'm sure its in the manual somewhere.
That said, I go steeper with my JD455 but its all about knowing your limits and the machine.
