  • Replies 22
Thanks for replies
I'm looking in to ways to make my machine to last for as long as possible.
I have done a setup now in my garage where i can drive the machine up so i can be below it in a safe manner and inspect every bit of the machine, and now wonder if i should replace all screws and bolts with stainless steel ones, see if i can improve it to last longer. I noticed already a screw is loose from the bit where the fumes goes out, dont know the english word for it, Exaust is the nearest i know the spelling.
Some bits can not have a rubber washer to stop vibrations.
How do you guys maintain and improve your stump grinders to last longer ?
I can easy see i can avoid a big cost by maintaining my machine, if i can keep the machine maintained and get it to run as cheap as possible i can supply lower prices and get more customers.
Trying to think outside the box here, and see if i can make some sort of improvments myself on the machine.
