  • Replies 51
yuk :thumbdown: fancy a long wheel base with crane behind the cab tp chipper with towbar for plant trailer & grinder not realy for off road work unless it calls for it :001_cool:
You will get stuck if you take a rig like that proper off road! The number of time we've got stuck upto the axles:sad: The ground needs to be bone dry and hard with a crane mounted mog
You want something like this or
no i dont:001_smile: if its that bad will use the tractor
Weight is a killer off road, a Unimog will go further than a 7.5t/3.5t but not quite the go anywhere vehicle, to heavy especially with a crane.
I reckon hucksters mog is best with the trailer mounted crane, most of the unimogs i've worked with have more road biased tyres as well.
big wide ag tyres and tyre inflation makes the world of difference
Yep that'll help a lot, you need to get the spec you want from the off, as it can get expensive to change things around.
