Just a quick question(or is it). What do you allow for planing/sanding when cutting unseasoned wood. For example If I want to end up with 2" thick boards what should I mill them out at? Does it depend on the species of wood? Thanks, Bri.
It depends on species, width of board etc, you need to allow 10% for shrinkage when drying, and a couple of mm a side for planing. Obviously a very wide cupped board is going to take a lot more planing than a narrower flat one.
Edited by muttley9050
