Makita DCS5121 muffler mod?
Duncan R
  • Replies 22
Told you so. DO it, you'll like it.
(Ah yeahh)
Hi Wyk,
It's purely out of interest really......the saw is working great and loosened up nicely, I can't see me needing anything else for some time so was just sat there earlier pondering, (in between thinking about what to cook for tea), the specifics if I went down that route.
We had Macaroni Cheese by the way........
Hi Wyk,
We had burrito's with mojitos. Coz that's how I roll.
I think if you do a google for 5100 muff mod, the 'other site' has some interesting threads and info.
Hey Dangerous Dunc! Glad you're enjoying the saw I advised you to buy!
Would have sucked if you hated it, right?
Wyk makes me laugh with his comments, he's a natural comedian.
Did you keep the little Stihl in the end? Tried using it after a stint with the Makita to compare the difference yet?
Cheers .
Hi TW,
I thought about keeping the MS but it wasn't going to get much use really so ended up selling it through gum tree for £145, honestly, I probably could of sold it 5 times over. The guy was very happy with it....taking everything into consideration he saved nearly £100 over what he would of paid from his nearest Stihl outlet. So much for selling it for £70, :001_smile:
I like the Makita as it just blasts through everything in comparison, no bogging down, sounds good, spools up well etc. although a tad heavy? not in a position to comment on weight for 50cc saws per se' as only ever used this one but it does have some heft to it. I am sure in time I would of found some use for the MS but by and large it would of sat in a dark cupboard feeling unloved, lonely and miserable...:sad: it's new owner has reported back on the Cherry trees that he needed the saw for and from the sounds of it they appear very happy together :001_wub:
Hi TW,
Just a thought , now that you have the faster , stronger, Makita ./ Would you pay £145 for that little Stihl ? :001_smile:
No........:001_smile:
one thing I am having a bit of trouble with you guys might be able to help with is that the Makita seems to flood easily. The last two starts from cold/using choke have flooded the engine, so I have to clear the cylinder, clean and dry plug, reinsert, choke off/half throttle off and she fires up sweet as a nut, if a little smokey until the unburnt fuel has burnt off.
Any ideas?.....the fuel has been mixed a little on the rich side but only by a very small margin, would it be advisable to start without choke and half throttle disengaged?
Bloody phone ! Try without your ear muffs on . you may find it fires on the second pull . Don't expect it to run on choke , just cough . Once its don't that choke in and pull till it runs . Usually 2 more pulls or so .
