The strimmer line fed through the fuel pipe gives the pliers something to grip on. Keep a good grip and you can push the hose into a tight hole with a bit of lube. You can also grab hold of the strimmer line on the other side of the hole and pull it as long as you keep it pinched with the pliers.
It helps in some situations.
  • Replies 23
[ATTACH]177430[/ATTACH]
Whats in the pot Barrie:sneaky2::lol:
