Out grinding the other day and the two big belts from the engine gave way :( anyhow shot off and got some, fitted them then re fit the small hydraulic pump belt but theres way too much slack in it!
Ramg vermeer who said the 4 bolts that hold it in place are elongated... No they arent :001_rolleyes:
Anyone know?
To fit the other belts i undid the engine slides and pushed engine forwards a bit, put new belts on then used bolts to move engine back to tension belt (crap design imo! ) maybe ive got too much tension on main belts thus not much on small one? Pass!
Anyone help?
Cheers
Only replaced the big ones huck, with same part code length etc. little one is old belt, was a bit slack before but nothing like this. Wonder if its stretched? Either way there should be some adjustment somewhere?
Cheers
