the first one is:
Powerful, light and very convenient in the application gasoline-powered saw with the high handles. It is intended for the work in the deep of snow and at temperatures to 40 degrees of lower than zero. Arrangement and height of handles contribute to the outlet of exhaust gases to the side from the user. The well protected fuel tank, located between the handles, ensures outstanding balance. The construction of handles makes it possible to turn the block of engine at angle to 90 degrees. 4,6 hp
So, your standing in deep snow and you use this for cutting timber which is covered in deep snow?! WTF!
