  • Replies 20
For what it's worth here are a couple of pictures.....
[ATTACH]176237[/ATTACH]
[ATTACH]176238[/ATTACH]
Doesn't look in bad nick, looks like it's from a dealer??
Not from dealer from a nice guy who takes them in and refurbs them... I thought it looked in decent nick also. Right then think my decision has been made. Into the Lions den I go...
hi i run the same machines thge only thing i would have against the one your looking at is that the infeed shute is the old type, jams more often and a little slower to feed. Great for domestic works as easy to push and alan is decent chap to deal with
yes it sounds quite a lot, but considering you should be able to get 5 years use and probably still be worth 3k once it is nearly worn out. I also would not worry too much about the hours as the clocks tend to break or get disconnected, mine had 1650 hours on clock before the wire fell off a couple of years ago and it still runs fine. The kubota v1505 engine will run forever if you maintain it properly. Keep the knives sharp and grease her up regular.
