Without wanting to appear outwardly thick :confused1:....The replacement chain listed in the owners manual is 513 496 664 (3/8" chain)....looking on the Makita web site that part number relates to different saw models...the stated chain on the Makita website for the 5121 suggests 2 x variations of a .325" pitch chain?!
What should I be looking for when ordering a spare chain for the standard 18" bar please?
It looks like 325 in the photo. It will state it on the tail end of the chainsaw bar.
I would keep that 181. It will come in handy some day. I use ours often enough for small jobs, or when I want a thin kerf, like when I am making wedges or have to cut a pattern in something like wall board etc.
  • Replies 60
Hi Duncan
The chain specs should be stamped on the bar usually near the drive sprocket end
A friend of ours has two 181s & really likes them, they cut a fair pile of firewood each year so dont be too quick to part with it.
N
Guys, I appreciate the details of the chain are stamped on the bar...it is a 3/8" pitch, when ordering a replacement what would the best options be reference manufacturer/type and is there any advantage in using a .325 chain/bar bearing in mind the saw is primarily used for occasional tree felling but mostly preparing firewood? Having only ever used the MS181 in recent years all I have ever ordered chain-wise are the Stihl Picco Micro chains by part number.
Hi Duncan
N
Hi NFG,
Already realising the little Stihl has it's uses.....the smaller/lighter, less aggressive nature of it (and chain type) has it's place i've found.
From what I can find on the 5121 as shipped from new. The chain is 3/8", well the know this already and the chain-bar gauge is .050" 1.3mm. I don't know how many links you need.
Full chisel will be faster cutting but semi chisel will be more forgiving, if your sharpening technique is a little off; and is good in a variety of woods, (hard - soft). Oregon's 'Multicut' chain cuts slower but will last longer between sharpening if you're cutting dirty wood.
Now saying 72DL.
and I thought it was 64DL (18"/45cm bar) :confused1: maybe best I count links physically? some sites suggest 1.3mm gauge others 1.5mm however it states 1.5mm gauge, pitch 3/8" on bar.
Thanks for the info' on chain types......
Hi again,
I count the drive links & measure the gauge with a vernier calliper or micrometer if you can get hold of one.
N
Hi again,
N
Not got vernier but it appears this is the chain in question...
73LPX064E
I will count links to make sure but I'm pretty sure that's the one..pleased I checked it out being 'Assumption' is the mother of all f**k ups :biggrin:
