They are coming up too exoensive for my budget, any further suggestions?
Use what you have as a deposit and vat then finance the rest. You would be far better off in the long run.
Need a chipper, which should I go for?
Looking at the small towable Echo Bearcat, or the DR XL, both around 3.8k. Really appreciate and advice/experience, thanks
Timberwolf 125, all day long. You haven't said what you'll be mainly putting through it, ie, are you into tree work, grounds maint, etc. we tend to do both and the TW 125 is perfect. You can manoeuvre it on your own, it's quite short in length which is ideal for domestic driveways, anything over 5 inch is for log sales anyway so for me the perfect all rounder. I almost bought the CS 100 and have used one since, so glad I didn't, it will have its place as I'm sure others on here will be quick to point out, like size and access but if you pick up a meaty job you'll see for yourself, for an all rounder TW 125....no brainer.
