Still experimenting with my kiln, getting good results, I was wondering about something like this to monitor the drying progress
PALLET TRUCK WEIGHT SCALE HAND MANUAL DOOSAN DELIVERED | eBay
I stack the IBC's two high in the kiln, I could weigh the each stack, calk the weight on the stack, then check the weight after a few days.
Any one done this or any one see any reason it would not work???
  • Replies 28
If you have a forklift or telehandler then crane scales may be a bit more versatile for other tasks. I suppose it depends if you would use them for anything else. CRANE SCALE 11023lb/4.4lbs WEIGHING DIGITAL INDUSTRIAL HANGING ELECTRONIC SCALES | eBay
That would require taking the cages out of the kiln though, with the pallet truck I could just go though the kiln weighing each stack.
Agreed. Never used a kiln but assumed it would be packed tight to maximise the heat. If you have the room to manoeuvre a pump truck then it would be far quicker esp if you can do two crates at once.
We had a set but the electronics gave up fairly quickly (and they cost alot more than those on your link). The 4' x 4' pallet scales didn't last long either but our crane scales keep going on and on despite being out in all weather.
Hi, do u sell it by weight?
I just drive into container with handler take cage out and rotate cage in to truck, tried rotating Ibc crates and they fall apart when turned up side down.
No,
See Marko's post below.
The easy way to measure % moisture lost; weigh them in... weigh them out
How do you know how dry they are???
