Does it all have to be assembled, belts on and tensioned etc, little confused about the little tab that comes off it, it says to not bolt this up... surely it wants securing then doing the engagement etc?
Yes fully assemble & operate, usually there is a tab to stop one part of the clutch body from rotating.
Thats it, so tab should be secured otherwise the whole lot would spin! Cheers
The Vermeer's usually have a slot cut into the guard for the clutch arm to locate into!
The arm needs to be able to float don't anchor it solid as this will prevent the clutch from working correctly!
It bolts to a little bracket below where the clutch is ithe a bolt and a rubber packer. Are you saying to set clutch up without bolting up then bolt up after.
Not fully tighten it up when finished?
Brandishing the clutch should only be done once it has fully been assembled as your basically 'running in' the clutch in its normal running position so it needs to be in that position before you start!
