Hi all, got a big crane job coming off, I'll be climbing for a company I sub for, only done one crane job on some poplars which were fairly straight forward, just wondered if anyone had any tips or advice will be appreciated! :)
Watch the videos from RCO
I like to use a short piece of rigging line on the hook and some spiders on that, that way you can use the spiders when you need to balance a section or just leave them hanging when you don't need them. The spiders are just a piece of 13mm climbing line with a loop either end, you tie a 6 wrap prussic onto the rigging line and adjust the length from there.
You can see it here:
[ame]
[/ame]
In this one the top is slung right on the COG, ideally it would have been higher so that it stayed vertical but it was a particularly nasty crack willow, and I couldn't take the risk of the anchor point snapping:
[ame]
[/ame]
Another heavy pick on the COG, a little too much tension here, it jumps off a little....
[ame]
[/ame]
What tree is it you are dismantling with the crane?
To tell you the truth in not sure, find out in the morning when I get there! Lol
