Chipper was fine this morning, now infeed won't feed in unless we have lodged a stick on to the button, is this bad for the machine at all?
ย
Haven't got the tools onsite to undo te electrical box and take a look in, it used to do this maybe once a month, but wOuld fix itself after pressing in the red button, hoping it's not too bad
I had a similar thing. If it is an intermittent fault then it might just be a case of replacing the relays at both the switch, and the roller. That's all mine was. Used to make me lose my **** when it played up, but such a simple, inexpensive fix. Hope that helps
Check the wiring under the hopper and going to the stop bar switch
ย
150 and 190 have plugs in the wiring ( can't remember if yours has as well !)
The wires sometimes get half pulled out and cause an intermittent fault, also the stop control bar switch get a fair bit of stick from the weather and road spray and once that water gets in its down hill for the switch!!
Is it the button type or paddle type ? My chipper had the button type and the switch and button went down, we were unable to source a new button and up graded to the new paddle type box from spectrum plant, but they did have some switches in stock worth a call
  • 3 months later...
Jut as an update, the spring had gone in the reverse switch, so the switch was being triggered by vibrations, 5 new switches for good measure and it's working away quite happily again!
  • ย
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. ย
If you're just starting out and you need business, equipment, tech or training support you're in the right place. ย If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,ย ย then you're welcome too.
ร—
ร—
