Hi
One for the admins:
If I go to arbtalk.co.uk all is well & works fine, but type in arbtalk.com I get a redirect to Google drive after a delay of about 2 seconds
Im not sure if this is intentional or not, it happens even if I deny scripts for arbtalk.com so I suspect its using a metarefresh tag to achieve it.
N
Hi
One for the admins:
If I click on arbtalk.com in your post it works .
Hmm,
Seems to be an issue with FF on my MacBook Pro, not malware, I suspect its the FF config, hosts file is fine & my network is too well defended for interference.
N
OK
I have discovered its a bug in a FF add on that removes the tracking code from google searches, Ill see if I can help the devs sort it anyway in case anyone else uses the add on.
Amusing as I dont use Google all that often, but shows how intrusive they can be
downloaded latest version & installed seems to be OK now
N
Edited by NFG
