Happy new year to all,
I've just bought/am buying an Alaskan mill and have a choice of ;
Granberg ripping 3/8 .063 114 drive links
Oregon chisel 3/8 .063 114 drive links
Oregon chisel multicut 3/8 .063 114 drive links
Oregon ripping 3/8 .063 114 drive links
Oregon semi chisel 3/8 .063 114 drive links
Stihl chisel 3/8 .063 114 drive links
Stihl micro chisel 3/8 .063 114 drive links
Stihl ripping 3/8 .063 114 drive links
Not sure which is the one for the job so looking to your knowledge and experience.
Thanks in advance.
You need one of the three ripping chains. All have their pros and cons. Oregon is cheapest and works fine; some find Stihl lasts longer between sharpenings but it costs a bit more; Granberg is more expensive but cuts a bit faster, leaves a slightly smoother finish and takes a bit less power from the saw, however you need a grinder to sharpen it as the cut down teeth are often too hard to sharpen by file.
Alec
hi, I got my mill about a year ago and am very pleased with the Granberg chain, as agg said you need a grinder or a diamond file to keep it sharp, I can recommend the Granberg precision grinder, very accurate and saves a lot of time, great tool. cheers
