lister diesel chipper
si0797
hi all newb here!
i have been given a chipper!i know lucky eh,not as much as you might think!it has a lister petter lpa3 engine,aircooled but had a problem with low oil pressure and has cooked engine,i believe it has a cracked head.
i know its a long shot but would anyone here have an engine?or know enought to give me hand to rebuild,im pretty good at mechaniching as i own landrovers so spend my life keeping them going!
anyways if anyone can help i would be very greatfull
thanks
Hmmm, a photo might help. Lpa3? Air cooled? Could be one of ours, a Danequip or an Arboreater maybe. Describe it if no pictures available.....
Or a Dosko, spares seem to be hard to get and we had a cracked head on one too.
Did the Doskos get converted to diesel by Danequip?
Those LPA engines were delightfully uncomplicated but could blow head gaskets fairly easily if the covers weren't removed and the fins blown out.
We used then for a few years and the were rated at about 25hp. Take the head off, flat it down on a sheet of emery on a flat service, fit new gasket and pushrod tubes then tighten it down! Nowt hard tbh as each pot was separate thing - all you need is torque settings and valve clearance distance. I don't think that expensive stretch bolts were required!
Come monday, ring GreenMech on 01789 400044 and press 2 when prompted then ask Mac or Jason if they can remember who their nearest agent was or google Lister and contact them.
An industrial diesel engine firm or a boatyard could help out if you cannot do it yourself.
Good luck with it - make sure that the infeed chute complies with HSE before you go to war with her!
