I'm looking to get a 201 back handle and I'm trying to find out if the sprockets are the same as the 200.
I can find info on 1\4 sprockets for the 200 but nothing on the 201,
Anyone know whether they differ or do they share the same ?
Cheers,
Si
Β
Sent from my Nexus 7 using Arbtalk mobile app
The most common sprocket for the MS200 is 6t 3/8th part code 1129 640 2000
Β
Β
Β
Doesn't look good unless you have a big hammer:001_rolleyes::lol:
Β
Β
Not following you there spud, that part no. was for the 201 1/4" sprocket assembly (with worm gear)
The ms 200 one is 1129 640 2051 (with worm drive)
I guess as they have different part numbers they are not interchangeable, ah well will have to put that on to my shopping list :-)
Β
Β
Β
Β
It's hard to tell if they're the same part number, some parts are given several numbers to stop people using old stock. Without physically trying to fit the parts, I couldn't say if there is a difference.
Β
Does anyone know if the standard 3\8 sprocket fits both saws?
As that's more common some of you guys may well have already tried them. Think I'll just phone a dealer up and see if he can compare them for any differences. I would have thought they'd be the same like you say just altering some of the part number might not mean there's any actual physical difference.
Β
Β
Β
Β
I would imagine that they would, only the first 4 digits differ, I also know the drum off an 009 fits the 200t
Β
Wisewood was asking if the sprockets for the 201 and 200 were the same - you put up the 201 part and I put up the 200 showing they were different!
Β
Are you following now:lol:
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
