Why an arc for height, to show targets?
Is the polygon of 4 compass points for crown spread simple or do you use interscting arcs from the stem?
Does the rpa follow similar rules to the old NJUG10?
It looks like a simple spreadsheet based on the xy coordinates could generate the above into a mapmaker layer and shading done by a style number based on the category.
Sorry, should've been more clear - the arc is for a rough approximation of the shade cast.
The crown spread is supposed to be fairly accurately represented, so generally a rough circle following the compass points measurements will suffice.
The rpa is specific to bs5837, and is based on the stem diameter, although it has some quirks with multi-stemmed trees.
Maybe with if you're good with that sort of thing you could set up a map maker thingumajig to do plot them automatically. Being a technodunce I just use Pear Tech's pt mapper!
Be interested to see how it goes if you try it...
  • Replies 20
