I don't have a clue as I thought they were all 70 cc saws .
Some Stihl models the word magnum meant something and on some it was just an advertising ploy . For example I don't think there is one bit of diff in an 066 and the mag model except the name plate . I will say this though a new MS 660 Mag will not in any way even attempt to keep up with a good old 066 . It might it the UK but here we get plagued by the EPA regulations .
Slower saws that cost more money,makes sense to me .:thumbdown:
What's the technical differences between a stock Stihl 440 and a 440 Magnum?
i believe that the mag is fitted with the factory dual port muffler, rather than the standard single port..
Cheers for the replies guys.
I have a 440 Magnum and it goes real well with no aftermarket mods.
Seems to have a bit 'more' over the standard one?
Mufflers and the like can be altered as far a duel ports etc . .
The older 066's ran like scalded apes . You didn't have to do a thing to them unless you wanted to . IMHO opinion the 066 ranked right up a par with the 038 Mag . It must have been a good one because it pretty much set the standard .As I said before the newer Ms 660 leaves a lot to be desired as compaired to the old stand by 066 . Kind of sad on this side of the big pond what the EPA has mandated for our saws .
