I used Liberon finishing oil on an Oak longcase clock, very easy to use and very easy to go from a mat to satin to high gloss finish depending on the sort of finish you want. It also dries to a hard finish.
It gives a nice deep colour - if you dampen the wood, that is the colour you will end up with.
I have used Casey Oils on gun buts before and this is very similar in use and finish - bit like a wipe on varnish!
