Sign in to follow this
hedgesparrow
MS170 having problems
have a ms170 been a very good saw but of late has been playing up hard to get going after its run out of fuel. when it does get going have to feather it to get it run smooth. today it just stopped and will not go. tried new plug good spark fuel is coming through feels like it has got compresion. but it will not start. checked filter in tank fine clean air filter is clean. at a loss what it can be apart from the carb needs a service, or it has some thing wrong on the engine side. like to try and get it working even as a spare. as got a second hand one which chain brake gone so swapeed over to that saw.
any help apreciated
Share this post
Link to post
If it has a exhaust screen under the deflector on the muffler check that.
Have to burn the oil/carbon build up out of mine twice with a torch.
Share this post
Link to post
If problem persists, sell it (honestly described) on ebay with a part worn bar and a part worn chain for £100 and get a new saw with a new bar and new chain for £170.
Share this post
Link to post
Dont run it out of fuel then! Easy.
Seriously though, its not that 170 kat that i remember you posting about a while ago is it?
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Tip site reviews
