ms230c chain
dig-dug-dan
From you description, I would say that you have a 3/8 low profile sprocket and have incorrectly purchased a 0.325 bar and chain.
Two options
1) Buy the correct bar and chain
2) Swap the sprocket
This would do it -http://www.lsengineers.co.uk/rim-sprocket-kit-0-325-7t-for-stihl-ms230-ms230c-part-no-1123-007-1032.html
Rim drive is a better option IMO.
Or this if you want a spur sprocket -http://www.lsengineers.co.uk/chain-sprocket-0-325-7t-for-stihl-ms250-ms250c-part-no-1123-640-2074.html
Avoid the "8T" options as it will make your saw boggy:thumbdown:
It will be worth double checking that you do in fact have a 0.325 chain but if the pitch is smaller (the rivits are closer to each other), It must be that.
Two options
thanks
Here is what i ordered:
Stihl 14" Chain Loop PM3 3/8 Picco 050 - 50 Links
Stihl Rollomatic Guide Bar 14" - 3005 000 4709
it was from lsengineers, so that link you sent looks the best option
thanks for your help!!
