07 Ford Ranger vibration in 3rd gear under load
hardtop110
Sounds like the needle roller bearing on the main input shaft has started cutting into the shaft causing play in the box , from memory third is direct with these boxes , you will most probably find that within the next 10-15k miles the synchro's will go in third and fourth causing it to graunch from second into third and third into fourth , from there you have about 10k before you will not be able to keep it in gear in third .
Thanks CTS
How big a job is it to replace the bearing? Or once it's started to go, does it take the main shaft with it?
Ta
can be a tricky job if you don't have the right tools
this vid covers the fundamentals -
[ame=http://www.youtube.com/watch?v=U7CaN2hdssk]Nissan Navara 4x4 center tailshaft bearing replacement - YouTube[/ame]
