Will the autotune on a 560xp need correcting if I change to ASPEN fuel?
The saw has only been used a few times. I've also taken the spark guard mesh out of the exhaust.
Any advice would be much appreciated....
Thanks, Timon
Thanks, Timon
Just keep cutting it will be fine . Its had aspen in before I expect at the Husky plant.
Thanks Stubby. I didn't think of that..
As stubby said.
At the worst you might have to do an autotune setup but tbh it will probably be fine from the off.
The autotune only starts to work after the saw is warmed up and been used for about 5 mins AND the machine is used on full throttle.
It has a sensor on the throttle so using it at part throttle wont allow the autotune to do its stuff.
I have some good pdf presentation on how it all works.
I will dig them out and get a thread put up.
As stubby said.
Nice one Mark, thanks.
Timon
