Clark Forest did them years ago.
I really want one i nearly got one at the APF. They're big money for a just in case tool really. Their very popular over in Finland/Sweden maybe one of the guys there can find you one and post it over?
Then your £300 tree jack will be money VERY well spent. Your back and high lift wedges will thank you for it.
I used them in Finland they're very cool. There is on on the Logasol website but it doesn't look in the same league as the orion ones.
Can't find it on the logosol site; you got a link? :thumbup:
PS there's 2 on ebay; look and priced v similar to reipal but doesn't feel right... ebay lol
I might just have to wait; probably get a few hundred over without it.
Do you cut a notch in the back of the stem for that to sit in then it leans against the tree then crank the lever and its like a telescopic boom? to push tree over?
You dont even need a notch it pushes a little spikey foot in. Its foot pushes into the ground and the top into the tree it reaches a point where its 'stuck'. Cut your desired felling cut. A danish works well as does a split level turn the leaver it telescopes out and pushes the tree over. Can do some impressive lean too.
