thin kerf bar and chain for 066 ?
biofix
Hello,
I am new to this forum and chainsaw milling.
If somebody could give me some advice that would be great.
I recently bought a Stihl 066 and I want to use it for milling (hardwood and softwood, mostly small logs) . I thought it would be good to get a 50cm thin kerf bar and a thin kerf ripping chain.
My question is: will the saw be too powerful for the thin kerf chain so that the chain might/will snap ??:confused1:
Does anybody have experience with big saws and thin kerf chains?
Thanks a lot
I use a 25" thin kerf (1.3mm) STIHL DUROMATIC E bar with a 3/8" Picco chain on my MS 660 for milling.
The STIHL part numbers are:
25" DUROMATIC E bar: 3003 000 5531
7-pin spur sprocket (Picco Z7): 1122/06
The duromatic bar (no nose sprocket) allows you to clamp the Alaskan mill close to the end of the bar nose, giving you a longer effective cutting length.
But to be honest, you don't save that much kerf width from using a 1.3mm kerf Picco chain, as compared to a regular 1.6mm kerf 3/8" chain.
Welcome to forum and interesting first post.
There's a lot of myths and legends about using 3/8 lo pro for milling.
First of all - thin kerf chains are really not that much thinner at all - they save very little wood compared to a standard 3/8 chain as demonstrated here~
http://arbtalk.co.uk/forum/milling-forum/44074-some-interesting-facts-about-3-8-lo-pro-chain-milling.html
But I think they do have their use in that a 3/8 lo pro chain requires less power to pull it through the wood than a standard 3/8 chain.
Looking at the set up you have though - a 20" bar on a Stihl 066 - there is oddles of power there so I can't see the benefit of going down the 3/8 lo pro route for that size bar/saw combo...
It's more if you were running a 36" or 42" bar on a 90cc saw I think you'd see benefits.
I have just got in some GB lo pro bars - not had a chance to run them myself yet but hopefully will be able to next week. They are in the selectors for Stihl saws here Guide bars
:001_smile:
I've just got one of the GB 42" bars off Rob to run on my 066. Should give me around 36" clearance on the mill.
I've not had a chance yet to mill with it but I want to do a time trial between 42" lo pro and a 36" standard 3/8
I have had a quick trial with it off the mill and found it was very grabby. It ran like it had another 20cc. I expect it will behave better in the mill. Wouldn't like to hit a nail with though!
Sent from my Nexus 7 using Arbtalk mobile app
I was thinking the same thing Si - I will do a time trial between:
Sugihara standard 42" with Oregon 75RD ripping chain - new set up.
GB 42" with Oregon 91R ripping chain - new set up.
And cut consecutive planks off the same tree!
Really the GB bars are just for milling....
:001_smile:
That sounds like a more accurate test Rob, personally I just want to know how it compares with my current set up on a 36"
If I can get this current job finished I will hopefully get a spare day next week to experiment :-)
