325 to 3/8
Supernube
hello i got a question is the sachs dolmar 116 SI a K095 OR K153 bar mount they look similar spacings but the chain adjuster hole and oil hole seems smaller on the K153 bar :thumbup:
My original S-D bar (and 1990's Dolmar replacement) , are wider bars than K095 with smaller adjuster holes.
The Oregon bar selector lists K095 mount for the 116Si.
K153 appears to be Large mount.
Husky small mount bars seem to fit O.K
The bigger holes on K095 will allow fitment to other saws aswell as small mount Husky and small mount Dolmar.
My "Wildcat" is a 1984 56cc 116.
  • Replies 44
Sorry to hijack. I'm in the market for a 372 (old model) to run on an 18" bar.
I have an 18" .325 Sugi bar handy (having just bumped my 357 down to 15").
Would an 8t .325 sprocket for a 357 fit a 372 so I could run my bar on the 372?
No, 372xp is d009 mount in both forms, and also has the standard size rim, so 9t is the only option
But... You may be interested in these part numbers
[ATTACH]167417[/ATTACH]
Thanks for your reply, so this means my Sugi bar is useless on the 372 then?
Humour a simple climber and explain those part numbers? :P
Yes, it won't fit, the mounts are different, but buy a husky 362xp and fit a 372xp top end and you're sorted.
Those part numbers are large mount husky racing bars, as used at the apf. You won't find them by googling them either.
Thank you. I'm not set on running 18" .325 on it, just thought since I have the bar already I may as well use it. I'll just stick to 18"-20" 3/8 7t like normal folk.
