Bought this mower 4 months ago and its been a life saver,knocks over 4 hours off my work load a week and not too mention trips too wheelie bin AND MY LEGS ,still manages a stripe and The customers love the fine finish .
It is for well maintained lawns and does not like tall grass
Bad points are it hates deep mossy lawns like most four wheel mowers.
When cutting wet grass you have too keep grass box lid open .
Have not tried the mulching plug has not a big fan of them and the side discharge chute is OK.
Major plus point is its short length means it will fit in my swb Iveco and still fit me Hayter/Honda roller mowers .
Ste
[ATTACH]166248[/ATTACH]
[ATTACH]166249[/ATTACH]
i have the older smaller model and the Z420 model ride on use both as mulchers. on the big one never had to resort to fitting a collector does a cracking job mulching. yes if grass is wet it does leave a small amount of clippings so a collector would help.
as for smaller one makes a cracking job in mulching mode if grass is damp then put collector on. but majority of time is grass is kept short no need for it
looking at getting the titan ride on with a 5ft cut so i can speed cutting up on larger areas.
downside on them yes drive on smaller one ok but belt may be getting worn.
on big one front tyres going flat now has solids so that problem solved.
but that's minor compared to the good things good on fuel even though petrol.
see if pic download of jobs done with the Z
since this picture was taken moss has gone so has the thatch now have 90% grass.
We got one earlier in the year. I find the wheel drive a bit under powered. How do you find yours.
Yep,drive is a bit under powered,might have the dealer take a look before warranty runs out
Ste
  • 3 months later...
