I've got snow tyres on the back of mine, that made a big difference.
I'm using mine to cart my apples to the farmyard from the orchards, over 20 tons so far and hasn't spun the wheels once yet, never mind get stuck. Usually towing an Ifor Williams trailer too.
Hi thinking of replacing my transit for a cabstar and was wondering if anyone uses one with the limited slip diff. Is it any good just wondering if it would make getting to yard better in winter. My transit does it fine with the right tyres and i don't want to make the mistake in replacing if its no good at helping with the traction.
This may be stating the obvious but a LSD will only help if you have unequal weight or traction on the drive wheels. So across a slope, tight uphill corners or one wheel on mud would make it usefull.
Weight and tyres make the biggest difference. You need to access where you go and consider if it will make a difference to you.
