Because you have sanded and applied a finish to the bowl, this protects it from oxidisation and UV light ( unlike the shavings ) in the long term the bowl will become dull brown , nearly all wood does ( on the surface ) look at a Yew antique !. The same happens with most cut wood in both dry and green form , although fresh cut , wet /damp wood can also be discoloured by fungal activity, this is noticeable on fresh pruning wounds or felled stumps . Dry seasoned wood is dull on the surface but plane or sand it and see the difference !!
As above.
Some beautiful olive ash from big J,
Dark etc on the outside and when i had it halved in thickness an amazing light coloured wood with great grain ImageUploadedByArbtalk1409514410.762387.jpg.202523282d83d7528d5d7477baa634ac.jpg
