My first post. Hope this is the correct section to post this question
I have a Qualcast Suffolk Punch 35s electronic ignition lawn mower that as be cutting my lawns for a long time with no problems, just a service at regular intervals.
But the other day while trying to start the lawnmower there was a bang which I believe to have been a back fire? After then the mower would not start
I checked the fuel and the carburettor that was ok and the compression
But unable to produce a spark at the spark plug
Being a electrical engineer I checked the cut off lead and the continuity of the ht lead all ok
Replaced the spark plug with a new one as there was no continuity on the centre electrode
Also replaced the electronic module 3 pole unit inside the flywheel with a new one
Which as all new HT and trip wires cables attached
And still no spark also removed the spark plug cap which from the reading as a 10k ohm suppressor built-in and connected the lead directly to the plug
Inside the flywheel the electronic module is screwed in place with no adjustment and the flywheel with the magnets build in are keyed to the shaft so there is no adjustment
There is a small voltage at the plug but nowhere a voltage to create a spark also turned the motor over with a portable drill with the spark plug removed and the thread connected to the frame
Has anyone any suggestions what maybe wrong with the mower that’s stopping it sparking at the plug
:confused1:
  • Replies 26
The module is encapsulated with only two wires coming out of the module the trip wire and the HT wire I have also tried a second module here is no coil that came be seen only the three metal parts coming out of the module there are there to pick up the magnetic field when the magnet in the fly wheel passes the module and with a bit of electronics inside and a transformer increase the voltage when the magnetic field collapses and in the last few days have tried a second module and did try with the trip wire disconnected because that seem to be a common problem that is over looked
But sorry to say no spark
As a matter of interest, how are you testing for a spark? Are you quite sure you do not have one.
If the coil is good and the flywheel magnets are strong you should have a spark. It is really quite a simple system.
Your problem may be elsewhere, such as valves.
