What grease do I need
Dryad's saddle
Just bought my first chipper a Timberwolf 150 DBh 6 inch and was wondering what grease i need ?
I would recommend using a K2EP long life complex grease normally
See below!
K2EP Lithium Complex Grease
K2EP is a premium quality multi-purpose lithium complex grease for lubricating all anti-friction and plain bearings for use in industrial and automotive applications. This highly adhesive grease has shown exceptional performance providing extended lubrication intervals, even under arduous conditions and over wide operation temperature range.
Features
• Exceptional mechanical stability extends relubrication intervals.
• Excellent oxidation stability provides lasting lubrication at high temperatures.
• Excellent EP and anti-wear performance.
• Good corrosion resistance protects components operating in wet conditions.
Applications
K2EP has been developed for use in wheel and other bearings and as a multipurpose grease for cars, vans, trucks, buses, coaches and construction plant such as bulldozers, scrapers, loading shovels and dump trucks where it will give outstanding performance. It is also recommended for use in industrial equipment operating at high temperatures.
As with all greases used for the first time, check compatibility with the grease applied previously and if necessary purge bearings prior to application. Likewise, as a general rule, take care not to over-lubricate and apply the quantity of grease recommended by the bearing manufacturer.
Operation temperature range -20ºC to +150ºC
Is it a chipper, is it a mower or another broken stump grinder who cares we'll fix it!
The blue complex grease is for extreme pressure applications eg pivot pins of a loader or digger subject to very high shock loading
Hence it carry's a higher cost
If only being used for general and bearing use - use the red and save some money!
Red & Blue lithium grease are the same price here.
That means they must be over charging for the red grease !!!
Lithium complex grease is exactly that chaps. It can be dyed any colour of the rainbow. There is no difference.
What you must watch for is the spec of the grease, not the colour.
We stock 12-14 different colours/grades of grease at any point, varying from just over £1/tube to over £20/tube.
The point being however, grease and oil are cheaper than steel and if you use a known brand you will certainly get what you pay for.
