.325 rim sprocket for 372xp
Dinosaw
Good morning chaps.
I am having great difficulty in finding an 8 pin .325 rim sprocket (large) to fit the 365 I have upgraded to a 372xp. I have several 18" .325 bars and would like to run one on this saw. Any source ideas? Thanks in advance...:thumbup1:
Check your 18" .325" bars will fit they as usually are small mount (Oregon K095)
365 and upwards require large mount (Oregon K009) unless you intend to modify.
It will be easier to put .325" sprocket or RSN on a large mount bar.
Run it 3/8 it will be in a word: better.
I dont think a big 8 pin .325 sproket exists.
It doesn't, as it isn't possible to make. The drive tangs would interfere with the splines.
9-pin is the only fairly common .325 option, but larger ones are of course made.
