I found the plastic shafts take quite a lot of the shock/drive out when hammering them in
I've had that when I've hit the hinge, good indication that more cutting is required
ian
  • Replies 31
doubt the plastic shaft will need rings as it's that hard to be honest!!!
Doesn't NEED them but I think rings will make them almost indestructible! Found they do lose the odd splinter of nylon. Also after using several different weights of hammer I found that heavier (over 2.8kg) ones tended to make the shaft jump out of the wedge!
