preparing wood for woodturning
chris hennelly
people do boil their wood but i don't know how to do it or how effective it is. could be worth looking in to though.
if you are talking about wanting to turn dry wood later in the year then rough turn it to about 1" and leave it for 6 months.
most woods will need the endgrain sealing once roughed out with a coat of pva to stop it drying too fast.
what timber do you have?
Depends what you mean by turning?
If you are cutting a bowl blank then you need to cut it now not dry it first. Look on line how to cut it to exclude the heart of the wood, otherwise it will crack. You can then as seven says, rough turn it, or dry it first. If you plan to turn a full branch/trunk, then coat the ends with old paint and let it dry for a few years first.
The best method I know is quite simple and very effective.
Collect the old stubs of candles and chuck them into an old saucepan. melt it slowly over heat and paint the ends of the timber with the wax. It slows down the drying process considerably and prevents most of the cracking you'd expect with plain old air drying.
useful for square blanks but can take years to fully season.
roughing a blank out drastically reduces the amount of time it takes to do this. i turned a cherry urn 6" in diameter and took out the middle and it has take only 4 months to dry. if i had done it the end sealing way it would have taken years.
if time is on my side i do use wax on square bowl blanks.
