The green is more in keeping with Rigidoporous ulmarius isn't it?
Hi Andrew,
You do get the moss on Rigidoporus ulmarius but I've not seen this fungus growing on ash. Historically it grew on elm hence the name but in my experience it now usually grows on sycamore. Perreniporia fraxinea is more associated with ash (again hence the name) and still has the moss. That was my thinking. Its a guess to be fair as you can't tell for sure from the photo, or at least I cant. Another one with moss would be Pseudotrametes gibbosa but its not that.
You thinking Rigidoporus then? What are your experiences in terms of the associated species of both.
Cheers,
Hi Chris; playing a bit of devils advocate a little bit as they both can be confused for one another.
P. fraxinea, in my experience, tends to look a little more yellow whist R. ulmarius a whiter colour on the leading edge, I recently found R. ulmarius on a Horse chestnut so not strictly confined to Ulmus.
But hey, I'm open to suggestions; as Sean says, take a slice and look at the spore tubes.
On the debate regarding the two similar genus....
Rigidoporus ulmarius - David Humphries’s Fungi Directory - Arbtalk.co.uk | Discussion Forum for Arborists
British Fungi - record details
Perenniporia fraxinea - David Humphries’s Fungi Directory - Arbtalk.co.uk | Discussion Forum for Arborists
A relatively wide host range for both outside of the Horse chestnut, Elm, Ash usual suspects
there are similarities in morphology and tissue, but enough differences to be fairly confident in the field
http://arbtalk.co.uk/forum/fungi-pictures/6233-perenniporia-fraxinea.html
http://arbtalk.co.uk/forum/fungi-pictures/6205-rigidoporus-ulmarius.html
hope this helps.......
