Any way I can test this for a spark ?
lakeyboy
  • Replies 20
Try taking the coil off and sanding the bottom of it and the mounting surface. Not familiar with the 210t but there may be an earth wire to the cylinder block which needs to be present if the coil is mounted to plastic casing.
