Our Mk watering unit could do with a demount system so we can use it for other
things like a tipper/timber/hiab truck. Its only used as a watering unit at the moment which is seasonal and a waste of a good truck. Has anyone got anything, may even consider a small hook loader?
Bob
could you not fit adjustable legs like they use with concrete mixers mixer.jpg
Thats the sort of set up I am after but I need the sub chassis set up with the twist locks , no luck on ebay so if nothing turns up I might have to get them fabricated or look out for a hook system .
bob
A bracket on each bit with a captive nut on one side and a bolt through will do it, half a dozen of them will be enough if they are of a decent size, if its only a couple of times a year twist locks could seize up any way
