If there was petrol in the float bowl when it was parked up it may have blocked jets. Strip the carb and clean them out with aerosol carb cleaner and air line if you have one. My niece brought me a generator same kind of thing last week and the pilot was solid and needed rodding out :D
Spray a solvent down the inlet as someone pulls it over. Contact cleaner works well. Keep spraying it and it may pull fuel though and start to run properly.
If stood for a while I would put a few ml of light oil down the plug hole, let it sit, then turn it over to coat the bore, then give it a go after checking the fuel & spark systems are good.
