I need a new tipprer pump for my 127, it needs to be 12v with a single outlet/inlet fitting and be capable of tipping about 2 ton. What sort of spec should i be looking for as in litres per minute, fluid capacity and working pressure? If anyone can directly recomend a particular one that would be great. Thanks, william.
The 8 x 5 is 2700kg gw i believe, so fully loaded i guess the tipper would be lifting 2 tonne, so about what im after. I think i might order 1,as at that price i dont really have much to loose.
