  • Replies 30
Used a Warratah head. They're basically John Deere Heads (or Timberjack) rebadged and red.
As for log max they have a good reputation and do some massive heads it wasn't until i googled them that they do some smaller ones.
3 knife keto 150 best head I have had for hardwood very short head goes round bends very well the 500 is really good too but hard to find and pricey
does that have tracks rather than rollers?
Not looked at the afm stroke heads but not sure they will be good for what I want.
Have seen the small keto in use quite impressive but stripped a lot of the bark off which is fine in firewood/chip but will also be used in chestnut coppice so need the bark intact as best as possible.
Neuson have strongly recommended the logmax 5000 or the 4000 on a long reach machine. Apparently they are a very reliable strong unit.
I think any roller head will take alot of bark of chestnut alot depends on what base you are going to put it on only benefit of stroke head is they don't need muck flow but the tapios stroke head used to drive me mad waiting for it to walk down the tree
Has tracks I have ponsse h73 now very good head but keto was much better in hardwood cut many tons with it
Thought so. The H73 is a great head done loads of birch with one.
I think any head will debark chestnut coppice if its young. Dead of winter job to coppice it i would of thought or tearing of bark will happen.
