I wouldn't have thought superglue would have stood up to petrol. Using mine without the sealer and it's still playing up so going to have to seal it
Sent from my GT-I9505 using Arbtalk mobile app
If you use it between the joint then it will fill the clearance fit between the hole and th eplug but if you put it on top of the join as in your image, it will peel off and jam the metering arm or jets in the near future.
I have experimented with these damn things and eventually made a stainless punch to put new ones in to MS200 carbs. Get it wrong and you either block the low speed jets in to the carb bore as that is where those little holes lead and the reason for the welch plug (Maintenance) or it will leak and you get idle issues as the fuel gets past the plug rather than being controlled by the L screw!
I have used nail varnish(didn't suit me:blushing:), epoxy (deteriorated), superglue (same), JB Weld (came out), Sealall (Best IMO), Loctite 270 (Never dried), superglue and punch (pretty good if worked in).
There you go, take your pick:thumbup:
