As the title says folks, it's a very clean FS410c Brushcutter 2012 model.
Runs for 5-10 minutes beautifully then just dies (sounds like it's flooding) then promptly dies. Cools and off she goes again.
Got a spark, plugs clean, not junk in the tank or the carb, I put a new spark plug in, fuel filter..
Stihl the problem persists! Anyone had any similar problems? Thanks in advance
Colin
Edited by theflyingscotsman
Sounds like a coil!! Or the plug!!!
You could try -
1.Change the plug
2.Have a (known to be good & working) spare plug to hand,
Run it to it stops,
And then check to see if there is a spark with the spare plug (screw driver can be good hold and earth the plug with)
3. Disconnect the coil eathing/stop wire as this could be shorting/earthing somewhere.
That should lead you down the right path..
Is it a chipper, is it a mower or another broken stump grinder who cares we'll fix it!
Fuel tank breather? Does loosening the cap make any difference?If not coil sounds a strong contender - when it dies and is hot check the spark quality.
Sent from my SM-N9005 using Arbtalk mobile app
That would mean dropping the exhaust off the to sport the score marks on the piston.. But once that baby's scratched it won't be restarting!!!
