Not bad prices there, is the 3mm stuff upto the job?
I don't know. I don't have it, i used someones who had a AT Osbornes guarding kit and they had it. Hence i suggest it as they can see in the dark and dont get sticks poking through the grill into the lights:thumbdown: Since the sheet is 500x500 and you want maybe 125x50 you should be able to stack it one behind the other.
  • Replies 32
Yeah it's a kts, few reasons I didn't put the block in the cab, the levers for the spools are mounted in the way, it's very heavy and would be very difficult to manuevre through the bottom window, and a bonus is it sits at just a nice height mounted where it is and leaves room for your legs when you spin the seat around. Only prob with it there you can't close window but block can be moved onto trailer if I need to.
