Comp climbers and there silky's
Dan Earp
Hi lads and lasses,
So for those of you that take part in comp climbs what do you ask of your silky. Are there requirements that have to be met?
If you could adapt the silky what would you do?
Have you lost time because of a particular problem using a standard silky ?
Any real feed back would be grateful
Thanks
Dan
Ok so the teeth could be removed then. I was going to use a Gom to base this on so 👍 also can the scabbard be modded ? For example a slice removed from the side wall for quick removal. Im also going to do a trial with magnets
The main issue is dropping it, if you can prevent that your onto a winner.
I know she uses a lanyard of some sort and also though about securing a magnet to keep it in the scabbard aswell as opening it up a bit
